O0ooAJoo0O wrote:'91 s13 DOHC (KA24DE) no mods yet180k miles
Ok heres the catch..
girlfriend puts HESS gas in it in AUGUST!, blew the head gasket.
towed back to my parents house so my dad can fix it. ITS now DEC 23, still wont start. He's got the thing back together, had a mechanic check it over, all is good. new vavles, cleaned head, new gasgets, new fuel lines, new fuel pump/filter/screen, new O2 sensor, all back together. hmm, cant get it to run on anything except carb cleaner or ether.
we've run the ECU codes and all i get back is....NOTHING, no blinks, no flashes, nothing. I know the ECU works, because when i run it in diag mode, and turn the ignition to ON the LED flashes for maybe a half a millisecond. the mech said bad gas, which gumms up the injectors.. so thats what were going on... any ideas, like i said, it will only run on carb cleaner or ether in the main vac line.
-AJ
[email protected]
Well, lets start from the beginning shall we.
1) Does your fuel rail have pressure in it? Yes, go to step 2. No - check your fuel pump, fuse, and make sure there's not a vacuum leak.
2) Crank the car a few times and then pull out the spark plug. Do you smell fuel in the cylinder, or on the plug? Yes, go to step 3. No - Your injectors aren't working and either are clogged, or not getting signal from ECU.
3) Check to see if the spark plug is getting the spark it needs to ignite the fuel. Yes, go to step 4. No - Ignition coil bad, rotor cap bad, or something's grounded.
4) If it does get the spark, is the timing correct?
There you have it, a basic flow chart for you to follow. This is assuming you installed everything correctly, ie, the crank and head timing is correct, and the distributor timing is correct.
If it cranks and starts up then dies immediately, check your MAFS and TPS.
Also do a reality check to to make sure every hose is in its proper place, that there's no vacuum leaks, and that every connection is correct.
