my goals is 500whp block
ke70 sr20det
Car: nissan silvia s13 2jzgte
ke70 sr20det
lancer evo 8 jdm
nissan skyline g35 2 door
toyota verossa
my power goals are 500whp m no baller go slow and steady with correct parts not a ricer as-well
i am confused in choosing the item
i am currently ordering sum parts for my block such as
1.cp piston .2 over
2.eagle rods or manley ??
3.acl bearing or clevite 77 ???
4.arp main bearing
5.new oil pump
6.new oil sump oem
i just need sum input on rods and bearings specially what is worth it for the car
and is there any need of ati pulley or m ok with stock pulley
this is my car dont have any pics
now t28 7spi stock motor
m planning on 2871 or 3071 top mount
[youtube]http://www.youtube.com/watch?v=LdWn3lt33vY[/youtube]
feed back is appreciated
JDizzle
Car: 1995 Nissan 240SX
1. CP Pistons are top notch, you'll have no problem there. I think you mean .020" or .5mm over though.
2. Eagles/Manley H Beam - They're both around the same price. LOTS of people run the Eagles and have no complaints so it's really up to you.
3. ACL/Clevite 77 - Again that's up to you, nothing wrong with either manufacturer.
4. You mean ARP main studs? Don't forget to get the ARP head studs also.
5. New Oil pump - Great time to change this since the motor is apart, you should also look at the water pump/timing chain. Make sure those are still good.
6. OEM oil pan - Why go OEM? Moroso and Greddy make larger baffled alternatives.
ke70 sr20det
ke70 sr20det
lancer evo 8 jdm
toyota verossa
@ jdizzle
1.yes pistons are top notch and size yes 86.5 i dont wanna hurt the sleeve to its potential
2.i am leaning more towards eagle but will the perform gud on power loads
3.clevite is good but arp has so many to decide i just checked mazworx cant decide what acl to choose
4.i have head studs arp new style and cosworth gasket
5.when build its necessary to take old one
6. i can think on this one might be greddy is better
i wanna ask one thing i checked mazworx they are also selling 19mm wide bearing are they good ?????? give me input on those
thanks for good feedback appreciated
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Get a Greddy, Tomei or Moroso pan for sure. Take your time.
ke70 sr20det
ke70 sr20det
lancer evo 8 jdm
toyota verossa
ill go greddy ...but i wanna go top mount turbo later will hta turbo work on it like fphta 30r or 35r
as for cams im gonna go s3 or s4 like codyace
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Those cams are both undersized for your power goals... For 500hp, you're going to want some pretty good sized cams, and you'll definitely want the 35r over the 30r.
On a side note, I demand pics of you with the cars you claim you own in your bio. ;) Something about your typing just doesn't add up to any of that.
ke70 sr20det
ke70 sr20det
lancer evo 8 jdm
toyota verossa
where to add pics if you think m pulling legs of everyone SIRRRRRRRRRRRRRR
PyR0NiAk
tinypic.com works well
ke70 sr20det
ke70 sr20det
lancer evo 8 jdm
toyota verossa
ok il do it tomm at office ryte now but ill post one pic of each my car or itll take hella lota tyme for me cuz its like 1000 pics
ke70 sr20det
ke70 sr20det
lancer evo 8 jdm
toyota verossa
my ke70 sr20det redtop s15 turbo
ke70 sr20det
ke70 sr20det
lancer evo 8 jdm
toyota verossa
my other cars with mee
STILL NEED A DICTIONARY
PyR0NiAk
Meh, can't see them at work. A dictionary is a resource for words and definitions, not pictures of people and their cars, so when you're trying to be a smart a** to me, at least use correct vocabulary. Maybe you need the dictionary? ;) Either way, I'll check out the pics tonight. If you really do own all of those cars, awesome. Maybe you should try typing like an adult instead of a 4th grader.
ke70 sr20det
ke70 sr20det
lancer evo 8 jdm
toyota verossa
hahahahahahahahaha yes i own all these sorry dont live in states so not a proper english ull use to it.....
PyR0NiAk
Explains a lot. The way you typed, I seriously thought I was talking to a child. You not being from the states explains the broken English, though. The cars look nice.
ke70 sr20det
ke70 sr20det
lancer evo 8 jdm
toyota verossa
hehe thanks
i wanna ask one question i have basically bought some parts for the engine ie
1.arp head studs new one
2.cosworth 1.1mm
3.exhaust manifold gasket
4.t2 flange gasket
5.3 bolt gasket
6.4 bolt gaket
7.5 bolt turbine outlet gasket
just basics .. for the tyme being can i use upgraded valvespring retainer ??? cams will come later i just wanna open my head once for head
ke70 sr20det
ke70 sr20det
lancer evo 8 jdm
toyota verossa
just change my water pump ..the old one was almost finished no teeths on it so swapped it from my other sr20det engine it was in tip condition so temps are showing good found out the radiator m using is from my friends s15 it was kazama ex car pink it turned out blue sard radiator i thought just oem with blue color .... lucky mee
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Wow, lots of nice and interesting cars. I wish more people knew about/used the Mazworx's head & main studs for their SR builds. The head studs they have made are still ARP material, but they seat completely into the block whereas the ARP studs do not fully seat. Their main studs also do not require you to machine the upper oil pan for clearance, but the ARP ones do. Good luck with the build man. Your Redtop looks really nice btw. Also, where are you located?
ke70 sr20det
ke70 sr20det
lancer evo 8 jdm
toyota verossa
thanks ...as for block i am thinking to get a complete short block from mazworx 2.2 litre not stroke just bigger pistons ... 900 i guess and they are in development of 92mm piston which will go 2.25 or2.3 dunno but same 92mm with stroker YOULL GET SR25DET..1JZ KILLER
PyR0NiAk
You can beat 1JZs with a 2.0.... Just sayin'
maverick06xx
homeslicej2 wrote:Wow, lots of nice and interesting cars. I wish more people knew about/used the Mazworx's head & main studs for their SR builds. The head studs they have made are still ARP material, but they seat completely into the block whereas the ARP studs do not fully seat. Their main studs also do not require you to machine the upper oil pan for clearance, but the ARP ones do. Good luck with the build man. Your Redtop looks really nice btw. Also, where are you located?
Which arp head stud kit on there website requires no machining of the head? i need to install my built head back on and wanted to know which ones to get...is this one yo re talking about
http://www.mazworx.com/index.php?l=prod ... ail&p=3063
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
Hmm. I will definitely take notes on this one about the studs... Sorry about the thread jack OP.
Amays U G37S
Car: shoes
Someone has a boost addiction!!!
Make a build thread and update it as you put your motor together with pictures!
:bigthumb:
