So how come I have heard that putting a huge exhaust on a N/A car will actually rob the car of horsepower? Either way, the throtle body in downpipe idea seems totaly pointless because as someone said, the turbine is already blocking airflow until it starts spinning. Regarding the electrically assisted turbo, it might not be the best way to do it, but getting rid of turbo lag is not just to get rid of the feeling. Let's say that you race cars as a proffesion, the smallest advantage at any RPM range is still an advantage over the competition. Though, I'm sure someone is already working on that since by the time I thought that a transmition with a continually variable ratio would be a nifty thing, they had already been researched for years, I just didn't hear about it.demcj wrote:it doesn't matter if you're N/A or boosted, backpressure is evil. remember that.
-demetrius
I walk away in shame after being defeated. You are the TRUE genius.PapaSmurf2k3 wrote:Overall though, not bad ideas. But I think I can do you one better. Who here has ever had a few drinks and gone to bed w/ some girl and started making out/fooling around. If anyone els is like me, your mouth gets WICKED dry after a while, but sometimes you dont really feel like getting up to get a glass, or your afraid youll knock it over/spill, so I think im going to someone mount a camel back (hydration pack that bicycle riders use) to the head board or something, so theres always a drink right there, and its spill-proof/leak-proof. the only problem is you have to remember to fill it up before you start drinking/doing stuff. lemme know what you think.
nicely said, but not completely correct. immediately going from a small diameter tube to a large one will not cause backpressure. backpressure only occurs when there's a restriction in the system. it could be going from one diameter tube to something smaller, a sharp bend, catalytic convertor, or a turbocharger (hehe). the exhaust gases will reach the restriction, build up, and even flow backwards.madbouncy wrote:Backpressure isn't what you want in any engine, you want velocity and flow. If you could get an exhaust that kept the gas moving faster than a small 2" but flowed as much as 4", that's what you'd want to use. You want the exhaust to get the hell out of the car as fast as possible. If you add a huge exhaust, the exhaust will be traveling pretty slow at lower rpms. However, the worst thing you can do, is have a 2" pipe and then go up to a 3" cat back. It causes a sudden pressure change and the air will cool down when it goes into the 3" pipe and expands, when it slows down it'll cause back pressure, it's like having the small flow volume at the beginning and then slowing the exhaust down at the end. The less energy the engines wastes on the up stroke pushing the exhaust out, the more horsepower you'll squeeze out. Lower rpm = less flow, so you want a smaller tube to eep vkelocity up, higher rpm = more flow so you want a bigger tube because you need the flow but you'll still want the velocity up.
Modified by madbouncy at 3:09 PM 1/28/2005
its called antilag systems, there are a couple ways of doing it. you most common is to use a seriously delayed ignition spark so that the exhaust valves open as the combustion event is still in progress. and using straight compressed gas to spin a turbing is a very bad idea because as the high pressure gas comes out, it expands and cools very quickly (think can of compressed air for cleaning your computer) and the thermal shock will probably crack somethingvariable nozzles were pioneered on F1 1.5l turbos making upto 2000hp and using variable nozzles and variable vanespr240sx wrote:I think that Rally cars dump raw fuel to make the turbo spool faster.I saw that on one forum a waaay back ago
would this be plausible in a street car? or does it make the car far less reliable?skylndrftr wrote:its called antilag systems, there are a couple ways of doing it. you most common is to use a seriously delayed ignition spark so that the exhaust valves open as the combustion event is still in progress.
