You went with the same size tire but was it the same manufacturer? Or a softer tire? ZR rated? Is there a mileage warranty difference (less on the new tires)? I also see a 1-2 mpg difference when we switch in CA from summer to winter gas.sublime187 wrote:.......My new tires are the exact same size as the old ones (225/55-17)........
And denser air means more power per unit voume ingested.qsiguy wrote:Just simply colder weather will reduce MPG. More dense air will require more fuel to maintain AFR's.
I used to fill 'em to 40psi.. When I got my new tires (225/55-17 94V), they said OEM recommendation was 32psi, I told them to fill them to 35. Would you suggest otherwise?maxnix wrote:TDon't get the dropping the tire pressure unless you are drving across fields.
