atn_chargers »
https://forums.nicoclub.com/atn-chargers-u132919.html
Wed Oct 28, 2009 6:30 pm
Are you sure that is the proper way to the a reset on the ECU? I thought this was the correct way:
"Operations Procedures"
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.2a. Fully depress the accelerator pedal (HARD).2b. Fully release the accelerator pedal.3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.4. Fully release the accelerator pedal (while the CEL is still blinking)5. Wait about 10 second.6. Fully depress the accelerator pedal and keep it for more than 10 seconds.7. Fully release the accelerator pedal (The CEL light will continue to blink).8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU. "
Anyhow, that is a good suggestion tollboothwilley. I have been driving pretty conservatively for the past couple of months due to the increase in gas prices. How many times have you reset your ECU? The power loss and the loss of my exhaust note is something I really need to look in to.
This is my to do list as of now.1. Oil Change2. New air filter3. Fuel injection service (maybe)4. Do a ECU reset
Anything else to add to the list? I really want this car to be running like it was new again. I can't stand to see my baby run this poorly.
