ddemier7 wrote:Any other suggestions?????
I don't know how I have missed this.
Let's get to the bottom of this.
What does your negative battery terminal look like.
Does it have
any movement?
Check the resistance from the negative ground terminal to the timing cover area near the top of the alternator.
A voltage drop test of your negative cable might help too.
If you have a short to ground in the harness that may cause both of those lights to illuminate.
You could try checking for power at the white and red wire at the alternator. It should have 12V key on.
It is also quite possible that gauge may have failed. Especially if you are not experiencing any problems with other electrical systems. Are you?
