mistamacadamian wrote:your dumb. #1 t3t4 turbos new cost around 550. #2 why the hell would you buy sr 370's when that t3t4 turbo you plan to buy would max out those 370's? it seems some body hasnt thought out their set up too well. i hope your **** blows and detonates just like my KAT DID.
and I hope your banned from this site. Wow, you're an as*hat.
Anyways, back to the OT. A good T3/T4 can be very cheap, or very exspensive depending on your power goals and how much your budget is. While 370cc injectors are cheap, they will max out when your only on around 7-8 lbs of boost on a big T3/T4 turbo. If you have a little more for your budget, I'd increase the injector size. For example, if you go with a E-mance tune, you'll save a bunch on fuel managment, and you can get the bigger injectors.
