My funky oil drain
Zenki21
Car: 1996 240sx
hey guys i just got my car back from my boy's shop. I was doing some of the easier work while he was doing the hard stuff like welding. Any who he decided to do the oil pan while i was at work . The welding good and it doesn't leak but im a lil concerned about the drain line it's a lil horizontal. The line comes straight down from the turbo but it has to loop around the ac. I mean he already did that test with the turbo off to see if the oil is flowing. It flows fine. Also Don't lecture me about the rubber return line i got it with a kit from jgs turbo the specialize in ka-t projects. Let me know wat you guys think. here's a pic
Easy Pickle
...that's not JB Weld, is it?
(my first ka-t oil return line was also a little horizontal right at the pan it worked ok for me...)
j-z
Car: 95 240sx
welded on as in mig or tig, or welded on as in jb welded?
teddy
Car: Saab Turbo and MR2
j-z wrote:welded on as in mig or tig, or welded on as in jb welded?
mehh...weld schmeld...they're all the same
Craving4Boost
Car: 91 240sx fastback
JB weld is just as good as welding when it comes to oil pan bungs
Zenki21
Car: 1996 240sx
nah it's mig welded all the way around he just put some super high heat silicone around it for peice of mind. Thanks again guys for the info.
crzycav86
Car: 93 Nissan 240SX KAT
It will be just fine.
GEO
Car: 95 240sx KA-T
umm.. JBweld is NOT GOOD AT ALL for the oil return. I speak of experience, LEAK LEAK LEAKS...
crzycav86
he just said it was mig welded. reading comprehension > you
and jb-welding works fine if you do it right. i've seen it on many unleaking setups.
Easy Pickle
Craving4Boost wrote:JB weld is just as good as welding when it comes to oil pan bungs
GEO wrote:umm.. JBweld is NOT GOOD AT ALL for the oil return. I speak of experience, LEAK LEAK LEAKS...
Chezedik
Car: 1991 Nissan 240sx
^ Good contribution?
virus77
Car: 95 S14, 71 240z, 97 e320
if you thread the bung into the pan and use jbweld to secure and seal it will be fine, but not using the jbweld to hold the thing in place.
SeVa-S13
Car: '05 GTO 6spd
Chezedik wrote:^ Good contribution?
I think he was pointing out that Geo was talking to Craving, not the original poster who had already said it wasn't JB weld and was indeed welded. Which is pretty funny with crazycav saying "reading comprehension > you."
Chezedik
Almost a good point, except that I was pointing out that someone just seemed to be upping their post count rather than contributing. But at this point, aren't we both guilty?
