Tictakman wrote:Now i know this probably doesnt compare to WD's burn pics but....
I just got back my engine friday and went to install it and now im having problems. the engine has an over bore of .20 with 8:8:1 comp, a 3 angle valve job, cometic hg, arp headstuds, shotpeened rods. jwt ecu program with 72lb injectors and a 300zx mafs on a 95 ka24de engine. i got the engine in fri night then went out, sat i plugged everything in and had injector leaks bc of a crappy bd top feed fuel rail. well i got that fixed and went to start it but my clutch pedal was stiff. come to find out my slave cylinder decided to go out on me. then i went out sat night.. sunday i replaced the slave and turned her over with nothing. then my starter died on me so i had to replace that. when i did get the engine to turn over though it seemed like it almost wanted to start. i get spark in the plugs and im getting gas. i checked the timing and it looks correct too. im not sure what else to try, im lost. now it didnt help that my batteries that i had kept dying on me but i think im gonna go ahead and get now spark plugs just to narrow down the list. which ones should i get though? i had the old ones gapped at .33 but now im runnin low comp so should that be different too? any help would be great on diagnosing the engine so it will run. does anyone live in the cincinnati area that might wanna give it a shot? im going to sleep, frustrated!
Cliff notes, new engine wont start. i get spark and fuel, and timing was set over and over again by fsm standards...
Zak
Did you actually have the starter tested before replacing it (either by yourself, or for free by bringing it to Advance Auto or Autozone)?
Because when I was puting my built KA24DE engine back in, it wouldn't start either and I thought it was the starter, had it tested, and the starter was fine...replaced the battery and it fired right up. I'd replace your battery, especially if you say it keeps dying on you...
Not to mention, I don't think the gaps of the spark plugs make a huge difference just when you're STARTING the car
