did you get the sway bar? and strut bar i believe? so coilovers are better your saying? cause my car is brand new like i only have 12000 miles on it but i dont wanna do anything to kill my suspension once again thanks for the help guysDJBeasy wrote:It looks good, but Im starting to wish I never got it. My suspension has been getting progressively worse and worse and I can only blame the Eibachs. I should have saved and went coilovers...
yea i know the thing is the 2009 altima sedan dont come with the bracket! which sucks and the crazy thing is that stillen didnt even know that, i researched it myself to see and the only one that comes with the bracket is the 08 coupe and the support bracket is called a "upper retainer".. so i been contacting stillen to see what there gonna do and they been telling me about there are have meetings with steve millen and the other dudes who install the fascia, i think there trying to see if they can get a support brace for my car.. i feel like if i spent this money on there fascia i dont wanna go out a drill holes into my car for there mistake ya know.. hope they fix this asap. once again thanks for the help.nismogxs21 wrote:basically the gap is jus from not having a support bracket. wat you can do is go to home depot & buy 2 straight metal support bars & mount them from you radiator support frame & jus have them hold the grill up so this way it will be more flush with the hood. did it to mine n it looks good as new![]()
theres a also a link for it but not sure where. my be under the DIY section
No I dont have strut bar or an aftermarket sway bar, but thats not going to prevent the damage to struts and shocks anyway. The springs put a beating on them. My front is so bad the last time I had the car on a lift the mechanic was able to EASILY push the wheels up and down, like 1 hand easy.KINGJON1983 wrote: did you get the sway bar? and strut bar i believe? so coilovers are better your saying? cause my car is brand new like i only have 12000 miles on it but i dont wanna do anything to kill my suspension once again thanks for the help guys
