My friends, ask and thou shalt recieve ;)
meminto
Car: S13 Silvia CA18DECT
Here is the first of hopefully a number of tech documentary type videos for the gold ol' CA motor.. Removing the camshfts correctly..
Its probably one of the simplest things to do, but most people just get in there and rip them out without understanding that they can cause damage and they can eventually fail prematurely later on down the track..
http://www.youtube.com/watch?v=rqBIFduj_lo - Part One
http://www.youtube.com/watch?v=-U4tHExgsFs - Part Two
Here is another one for you all, this is about upgrading the ignition system.. I will add to this one as I physically install it in the car..
http://www.youtube.com/watch?v=Q3aJN4af5AY - Part 1
http://www.youtube.com/watch?v=pGDYC8w0vVs - Part Two
http://www.youtube.com/watch?v=3SRJRZcDejQ - Part Three
http://www.youtube.com/watch?v=AtIFt2O-fjM - Part Four
http://www.youtube.com/watch?v=lT4R0L2_JXs - Part Five
Enjoy...
Modified by meminto at 4:33 AM 10/14/2009
Modified by meminto at 5:09 PM 11/6/2009
rico05
Car: 1992 RMS13 w/ CA18DET
Very nice production. For someone that has never done this, and is unsure of the steps in the factory service manual, it will be a real benefit. I, unfortunately, did not watch both all of the way through as I have done this process enough I can do it in my sleep and I frankly got bored and started clicking associated links on the side. But I am sure you wrapped the job up nicely.
davidricardo86
Car: 1992 Nissan 240SX SE
Can you explain in detail how you reinstalled the front camshaft seals? Or did you have a machinist do it for you? I am having trouble with mine. thanks
meminto
Hi david,
what trouble are you having?
I can post up an overview in a few hours as I am on a mobile device and it is harder to type lol...
davidricardo86
meminto wrote:Hi david,
Heres the procedure from the FSM. I've tried this method but it does not work for me. I'm probably doing something wrong otherwise i wouldnt be on here asking. Sorry im just really frustrated that im being held up by a damn seal.
meminto
No dramas, I will get back to you in a few hours
bentvalves
Car: 89 Silvia K's
just snug that front cap up, dont torque it down and install the seal square. If you are having trouble inserting evenly, you can use the old seal or a big socket as a even loading tool so to speak.
davidricardo86
ks13 wrote:just snug that front cap up, dont torque it down and install the seal square. If you are having trouble inserting evenly, you can use the old seal or a big socket as a even loading tool so to speak.
I tried using a big socket but wrecked 2 seals doing that. It kept distorting the o-spring inside the seal lip. The spring is very fragile and the seal itself is very stiff and non-flexing towards the outer edges when trying to squeeze it over the outside diameter of the camshaft. The inside lip is flexible but very difficult to strech over the shaft without damaging it.
I have an idea, what if i heat the seal until it becomes more pliable then try and tap it in using the socket method or just a mallet.
mr.mk1
Car: 1969 Mk1 Escort CA18DET, 1964 Mk1 Cortina Estate
Subscribed!
bentvalves
Car: 89 Silvia K's
you really shouldnt need to heat the seal to make it pliable for install.
i left the front cam cap a bit loose and installed the seals by hand with motor oil.
davidricardo86
I think ive been buying the wrong part. It seemed too small for the camshaft diameter.
zmannz
Car: 89 s13 coupe- track car
92 s13 coupe- dd
Are you greasing the crap out of the inside of the seal?
davidricardo86
yeah I have! It is the wrong seal. It's too small compared to the old one I took out.
meminto
Another one added!
meminto
Updated, all five parts lol...
mazikowski
Car: 2013 Subaru BRZ Ltd 6MT, 1984 CA20E 200sx, 1981 L28E 280ZX
I absolutely LOVE your accent
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
mazikowski wrote:I absolutely LOVE your accent
i was thinking the same thing! I wish i had it, i'd get all the ladies hahA
ILOVESILVIA(S13)
Car: 93 Ca18det Hatch, 03 Subaru WRX Wagon (daily), Subaru Legacy Limited GT (daily)
This is crazy! I suscribed to your videos a couple days ago before you posted this up. HAHA! Good videos by the way! Keep it up.
