my friend's S14 window is stuck.
jinjinweiwei
Car: 95 240SX
you can hear the click sound when you pull the switch up or down but the window just wondt move. and he just swapped a new motor on that window. and that window is always slower than the other one. could it be something got caught? thanks!
stopatnothing
Car: Scooty Puff Jr. and NEW! Scooty Puff Sr.
I really don't know what it could be, but I'd pull the track out and see if anything is stuck in there or see if anything is getting caught anywhere.
Its easier if you pull the actual window off by itself and then pull the track out, at least it was in my case. There are only 4 bolts (I think) to get the track out.
jinjinweiwei
Car: 95 240SX
ugh... we tried to take the panel off today and hit a newbie problem...how to remove the door panel from a S14? lol thanks!
stopatnothing
iirc its not too different than an s13. Basically there are 2-4 screws strategically placed around the door. Normally one near the hinge, one in the little bucket handle-thing where the window switch is, and if its the passenger side then you have the one in the handle. Take a flathead screwdriver or something similar and use it to pop out all the rivet-things around the door (youll known when you get one, they pop quite audibly), once you get that, lift up on the door panel to separate it from the door, disconnect the plug on the backside and there ya go
jinjinweiwei
Car: 95 240SX
ok. got the pannel open! and we find out a little white box (where the wires of the switches go to) is making the click sound. has "AMP" written on it. does that mean the motor is dead again?
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
try replacing it, i had the same problem and replaced the white box
i got mine off my car if u wanna buy it =D
jinjinweiwei
Car: 95 240SX
try replace the white box or the motor?and what is the name of the white box?
MoldyOldy240
Car: 1991 240sx 295K w/ original engine.
jinjinweiwei wrote:try replace the white box or the motor?and what is the name of the white box?
That is the window motor AMP. It amplifies current.
Try wiggling and cleaning the connectors; that happened to my S13; it was just loose.
vancouverbc
Car: 1991 240sx
i assume it is a 95 since it has the amp. look up window amp in my tutorial link in my signature. it explains how to repair amp.
jinjinweiwei
Car: 95 240SX
^ thanks! i am gonna try it tomorrow
jinjinweiwei
Car: 95 240SX
btw does anyone have a walkthrough on how to replace bumpers? gosh i got a lot to learn but thanks for helping me out.
jinjinweiwei
Car: 95 240SX
took little amp out today, and there is no sign of broken connection. everything looked fine.... i checked ur tut vancouverbc very helpful. but now i looked at window diagnoses the other cause of this is the window regulator, is that the motor? and if so why the motor keeps on dieing on this door?
vancouverbc
Car: 1991 240sx
the regulator is integral part of motor assembly, im guessing. reg is the gears if i remember. or the part that connects gears to window.
jinjinweiwei
Car: 95 240SX
so... a new motor? but this will be the second motor he is going to get. and why is the motor keeps dieing?
vancouverbc
Car: 1991 240sx
jinjinweiwei wrote:so... a new motor? but this will be the second motor he is going to get. and why is the motor keeps dieing?
hook the old motor to 12v ie car battery. pretty clear that motor is not problem. i would guess the amp needs replacing. make sure the window is not stuck. you should be able to hear the motor though, if it is stuck.
Modified by vancouverbc at 5:05 PM 12/19/2007
jinjinweiwei
Car: 95 240SX
hey RJ i might need that white box, let me know the price.
-RJ-
20 shipped
jinjinweiwei
Car: 95 240SX
^ got paypal sir?
Silvia14b_TX
Car: 1995 Nissan 240sx S14 Zenki KA24DE
vancouverbc wrote:i assume it is a 95 since it has the amp. look up window amp in my tutorial link in my signature. it explains how to repair amp.
Thank You!!!
