My first weird problem with the G37
audtatious
Well, auto-up is not working on the power windows and anytime you open the passenger door the window rolls itself 3/4 down.
Annoying but funny at the same time.
telcoman
audtatious wrote:Well, auto-up is not working on the power windows and anytime you open the passenger door the window rolls itself 3/4 down.
Take it back to the dealer for an explanation
Telcoman
G37 Man
Car: G 37
did you disconnect the battery for any reason before this happened?
audtatious
Telcoman
Yep. If it was not supposed to snow today I would take it in this morning as the loaner is supposed to be the Service Managers M45x for a road test
I also have to get a piece of the cup holder fixed
audtatious
Nope. Pulled up into a parking spot and when the wife opened the door the window rolled down
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Did you try resetting the automatic up positioning?
If you are taking it to the dealer anyway disregard this. For any of the other people who experience this a quick test that may save you a trip to the dealer.
~First off close the doors~Put the suspect window up using the switch, not in the auto (there are two position settings) ~Once the window is all the way up continue holding the switch in the up position (not auto)for ~5 seconds. ~Try operating the window manually down then up to verify operation.~Once the window is down pull the switch to initiate the auto up function. If the window goes all the way up and operates correctly now then the position learning was erased and is now reset.
If the above procedure doesn't resolve the problem then the motors ability to retain its closed position may be lost. Although I have yet to see a 37 window motor fail (the switched suppliers from the original 35s I think).
Keep us posted on what they find Matt.
audtatious
I'll give it a whirl. The window goes up and down just fine (except auto-up does not work) and only rolls down when the door is opened up. FWIW, drivers-side window auto-up does not work either but at least it does not roll down when I open the door.
