Q45tech, I say this all with a smile, so please don’t be offended. You should work as either an accountant or an engineer, as your information is 100% accurate, but not useful. And, I can say that because I’m a CPA, so I understand.
Every hear the old joke, ask an account (or engineer) what color that horse is over in the pasture, and he will answer, brown, “at least on this side?” 100% accurate, but what’s the point?
My little test drive was anything but scientific, that’s the reason I referred to the “Butt-O-Meter.”
Now if I had a manual transmission and a strong clutch your calculations might be a valid argument to my claims. Your numbers are only useful if I was running on a on a flat road, steady speed, no tail or head wind, and the transmission operating perfectly with the torque converter locked up.
My test drive was on a stretch of freeway with a noticeable incline, I had the pedal to the floor and was accelerating for everything the car was worth. Do you think the torque converter was locked, or was it slipping as it is designed to do?
Another problem with trying to calculate RPM to MPH is my lack of detailed observations. In fact, I barely looked at the instruments, and seeing the needle at almost 100 MPH, I experienced the “OH ****” alarm as I realized I was going fast enough to spend time in jail and get a reckless driving ticket if the highway patrol caught me.
I was watching the road, not the instruments. I immediately let off the gas and applied the brakes to bring my speed down to something much safer and legal.
I stated honestly, what I saw on the tach and speedometer, not exaggerating, bragging or even speaking metaphorically.
Q45tech wrote:"the tach was swinging past 6,000 and the speedometer was just about touching 100 mph."
Metaphorically speaking?
91Q gearing that might acheive 100 mph assuming oem diameter tires:[2nd gear 7400 rpm] [3rd gear 4800 rpm][4th gear 3333 rpm]
