my first how to (foglights)
nismo1219
Car: '12 Nissan Altima 3.5SR
'99 Nissan Maxima GLE
NOTE - ok, so i decided to go ahead and write one of these to be of any assistance i could for any other idiot/inexperienced nico members out there. i used to crawl under the car and wedge myself up between the front bumper, splash guards, and tires to get to these little "pains in the ***" but jltibbs showed me otherwise and i thought id show the rest of you who migt not be aware of this.
DISCLAIMER - dont give me crap if you mess up your car, these are just steps on how i did this, if you mess up your car - its YOUR fault!
1st - start off by removing the plastic shield on the side of the light. depending on which side your doing, its towards the center of the car.
2nd - unbolt the two 10mm screws on the top and bottom and slide the housing out fowards
3rd - unclip the wires/fuse from each other
ok, now then take a look at what you have. you should have 1 housing, 1 bulb w/tail, 2 10mm screws, a plastic shield, and a plastic clip. if your replacing a broken/cracked light then you'll probably have to put your things together. i left mine intack to give you an idea.
4th - unscrew the black water-seal and unhinge the rear swing-door.
5th - plug in your bulb of choice and align it within the housing. now, close and secure the swing-door then replace the black water-seal you just removed.
6th - take a look at your housing and make sure you get the nipple into the plastic hole, then fasten the 2 10mm screws back into place.
7th - re-install your plastic side shield
8th - snap your pastic clip back into the shield to hold it in place
Finally - drink a pepsi and enjoy your quick "do-it-yourself" project and your new housing/bulbs!!
danielekfuj
Car: miata, rocket ship
maxhopper
Car: 02 Maxima SE 6spd
Nice job Ben! Added to the FAQ list.
Although.....I wouldn't mind some pics of you wedged between the bumper and spash guards.
nismo1219
yeah, it wouldve been pretty funny for an on-looker! i absolutely dispised my foglights before jeremiah told me the easy way! i felt like such a retard, !
MaximA32
HAHAHA! You couldn't have just looked in an FSM for that? I bet even Haynes tells you to do it that way...
nismo1219
what can i say...slow learner! LOL! i dont have a FSM, i bought the car used and it didnt come with one. i do however, have a haynes manual.
maxhopper
The same place I told you to get the Altima FSM has the one for your Max as well.
nismo1219
live and learn, huh. at least now i know...and knowing is half the battle! LMAO
