Dyno attaches to wheel lugs. Pretty slick setup.
Engine is basically a stock RB26 with FMIC and an open 3 inch exhaust. Running on stock ECU, 9PSI boost.
Here is video of the pull on you tube.
http://www.youtube.com/watch?v=UsonYhciLCk
It was 359 WHP, 283 WTQ. I am very happy with that.
What concerns me was the AFR. The numbers are too high for my comfort. Here is what we got from the wide band clamped to the tailpipe.
It should be in the 12's.
I was wondering if the tailpipe method of measuring the AFR is fairly accurate. I'm thinking of putting a wide band in the downpipe and seeing if it makes a difference in the AFR numbers.
Gord
