Megaseth »
https://forums.nicoclub.com/megaseth-u593.html
Sat May 29, 2004 6:13 pm
first off, the gravel WILL mess your tires up. it may not be full contact with a surface, but gravel is pretty harsh. and it tears up the underside of your car too, as well as the reaf valence panels. and staying in 1st is pretty bad for the engine seeing as how the final drive is a 4:10 and first gear is almost a 4:1. in english, this means first gears goes by quick and the engine revs up fast and hard. and i dont even think thats really drifting, more just breaking the traction lose and sliding over, not sliding in a turn. i did this a lot and never considered it a drift. the easiest way is to make a turn, "clutch", downshift, rev "let out clutch". however, i dont drift although i guess i should because i own a 240....
