Jesus already at 26000 miles? Thats ridiculous.
Yea I took my car in as well. They couldn't do anything unless the engine light was on. Just to diagnose it would be $120. But I think I figured out what the problem was, which may sound stupid at first but I'll explain. To make a long story short, I MAY HAVE put diesel fuel in the tank. Nissan wouldn't cover that s*** anyways.
I work for parks and rec and in the maintenance yard they have two gas pumps: Diesel and Un-leaded. My car was empty while leaving work, so I borrowed one of many 2 gallon red tanks they have in the garage just to give me enough to go to the gas station. Usually they are labeled "Gas only" or "Diesel" or "mixed oil". This red tank was NOT labeled, but was the only one that was full at the time. I figured most of the vehicles use unleaded oil any ways. As I filled up only 2 gallons of it, i noticed when I spilled a little on the ground it didn't evaporate as quick as gas does. I never dealt with diesel so I figured "hmmm probably just because its cold outside". Then again, it could've just been some old gas thats been sitting there.
Then you know the rest. This also probably explains why my tail pipe is black as s***. So what I'm doing now is wait until I'm near empty, put in some Techron fuel injector cleaner and pump a tank of 91 gas from cheveron, just to get some clean gas going through. I'm HOPING this is the case and that will fix it. My spark plugs probably took a toll on this being that diesel trucks, to my knowledge, dont have spark plugs or something lik that.
