ShadowsFa11 wrote:
Good info, thanks alot. Should I have the rear damper setting lower than the front to reduce oversteer? I have very little weight in the back of the car as I removed pretty much everything.
as i said before... a square setup
to start is the way to go... unless of course you have bigger sways or something else that would cause oversteer.
the reason for this is because with the tight cornering of most AX courses, understeer is way more common... you will tend to drift your way out of corners if you get on the throttle too early, but that is more of a throttle control issue
i always say to start with the settings the same all around.... if the car oversteers too much,
then adjust it down.... unless of course it is hard to adjust... if its not too bad to adjust, you WILL have time between runs to adjust it to your liking
Caveit77777 wrote:This isn't exactly a race tip but its still damn good. Idk how your auto x will be setup but I know at the one I go to its in a fairly secluded area with no food or drink vendors sooo bring your lunch
this is also true... ask your local people about this though, as i know my region always brings in vendors regardless of where we are
