my first auto cross this sunday....tips?
All over the world, Nissan products are involved in road racing, track days, time attack and autocross.
partymonster 975
Car: 03 Maxima SE, 94 Corolla
So, I want to get into the sport and I'm gonna have my first even this Sunday. I'm gonna be driving my 94 corolla, its a learning experience so my goal is to not hit any cones, then after that to just improve each lap time. Any tips. Its an "auto sprint" but i dont think its gonna be different from auto cross. My car is a 94 corolla, auto, with a 1.8L, 115hp engine. Does anyone know what cc that is?Here is a map of the course.So, any tips/advice?
crackler
Car: ZOMG JDM TYT3
1.8L =1800cc IINM
Look as far ahead as possible, then when you think you are looking far enough ahead, look even further ahead. if You are looking far enough ahead, than you should never be surprised on course, unless you are driving like a grandma.
Turn in EARLY on slaloms, way earlier than you think you need to, try hitting the cone with the rear tire of the car. looks like no slaloms for you on that course.
try to hold as tight of a line as possible and let the car push out.
Try to make as many straight lines out of each section as possible.
Smooth hands, and feet, think of a string tied between the stearing wheel and the gas/brakes. The more wheel you use the less gas and brakes you have available traction for. And be smooth on and off the gas/brakes. Think of an egg under the pedal.
slow in / fast out
you will need to have at least 35psi in your tires. on my 240 I ran 38/40 in the front and 36/34 in the rear, in that ball park. get some chalk and mark the sidewalls to see how far you are rolling the tires. if the car oversteers, drop rear pressure. if it understeers, try more front, but you may have to play with the rear as well to balance it out. tire pressures can get tricky. remember that as the tires heat up, they will raise pressure, so you will probably have to bleed them down some. Talk to some one local w a rwd car with similar weight and on street tires, to see what they are running. I'm on Azenis and run 36 front ans 34 rear, for now, but I haven't found the sweet spot yet.
brake in a straight line, hard.
lay your seat back, let as much slack out of the seatbelt as possible, then jerk on it to lock the retractor, then raise your seat back up, poor mans harness. You can also jerk the belt to lock the retractor and then twist the ends a few times to take some slack out as well.
late apex's are usually the fastest line on an autoX course
Don't be afaid to hit cones, that **** will buff out.
Thats all I can think of for now, here is a couple links that have some good info as well.
HAVE FUN!
And don't worry if you get smoked by some one in a "slower" car, they probably have been doing it for a long time, don't worry about where you are in your class, just work on improving your times.
http://sccaforums.com/programs....aspx
http://mokanmotorsports.com/fo...=1320
crackler
Car: ZOMG JDM TYT3
So how did it go???
Razi
Car: Moo
lol maybe a cone killed him
Kataki_
Car: daily 95 s14 autotragic project 92 nissan 240SX fastback rip93 fastback 1st car
or maybe he hit a giant bear. that would hurt
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
cracker, nice tips should help when i start
Return to “Nissan Road Racing / Auto X Forum”
