jsl74 wrote:Thank you very much. I will hopefully get to this soon. Did you noticed any difference in performance?
As for as a difference I can feel... the best way to describe it is that from 5.5k to the redline before the spacer seemed like the car lost a some power. With the spacer the car seems to have more pull at 4.5k to the redline.
A few more pictures:
Borla System on the floor
More Borla
Stock System after it was gutted
One of the tips after the install
More installed pics
The car is still dirty as of now... but she's getting the works tomorrow, so I'll get some nice pics of the whole thing.
I still lack any decent recording equipment, but this system added a much deeper tone over the stock exhaust. It sounds deep and mellow from 1.5k-2k RPM. 2k-3k is when she starts to open up and lose some of the deep tone. 3k-6.6k... you just let the beast out of the cage.
As for the expense so far... I've probably spent around $1200. Next mod is going to be the wheels, but I've got a bit more research and saving up to do before that happens.
**I know a few people have complained about leaks with this system, and I admit that I do have one (or what sounds like one), but it's only present if the car is in neutral and being revved. Specifically, it only happens when the RPM's are going down at right around 2k. I think it's coming from the H-Pipe, but nothing I've done so far will make it go away. If anyone has encountered this before and has any ideas, let me know.
This doesn't effect normal driving though. She's nice, clean and deep while moving... the leak never becomes audible (I even tested by driving by someone outside the car)
Also, a note to those that plan on swapping exhaust: The absolute worst part is pulling the catback from the hangers. My arms were beat after that - They were also covered in WD-40 that was used as hanger-lube. It also helps if you've got another set of hands to help you manuever it while removing it. (I also raised my jack up with a towel on the support to prevent the exhaust from falling on me - The stock catback is pretty heavy)
