Fenris »
https://forums.nicoclub.com/fenris-u36657.html
Wed Feb 08, 2012 7:44 am
If you want an RB20, get a CA18, will put out similar power, be much simpler, and require much less upkeep (33% less!) 6 cylinders in 2 liters was not one of Nissan's best ideas... Whats next, a 4liter V12? (Toyota did make a 5 liter V12).
KA-E's are spunky, and if properly maintained will give you a constant power curve exactly where you expect it... but that power, there wont be much of. DE's are a slight improvement on the same situation.
SR's are simple easy, and you can build one in 2962646826582693846 different ways and get as many different results.
RB25-26 are both great motors, pricy, but well worth it. Only draw backs being how complicated their installs are and weight. (26 much more difficult than 26).
LS1 swaps are becoming more popular these days as well. 5.7 V8 fits surprisingly well in an s13, in stock from will give more power than a mildly built SR, rb20, or CA, and as much or more than the RB25/6.
KA-T options will do as much as an SR/CA/RB20 but with a very different power curve.
In the most general of internet biased terms and IMO:
Drift:
SR (middle of the road as always)
CA (Light and peppy, high rev limit)
KA-T (Plenty of power)
(LS1 and RB25/6 can do well here, but through sheer power rather than balance)
Drag:
All but CA (CA can drag, but each other motor would have a leg up identically configured.)
Grip:
CA (Lightness counts huge)
SR(Middle of the pack as always)
LS (NA with high torque and no turbo lag can be huge in the corners)
(RB series motors in S13's show their weight in this type, and pure power sometimes cant counter it, KA-T is off because of the length of runs. I agree a properly built KA-T can be strong on quick runs with drifting and drag, but it is still not a motor designed for forced induction and how it may hold up lap after lap really relies on the quality of the rebuild)
RB20 would slot between an SR and CA in any of these places, due to cost, age, and how complicated they are. Head to head, CA18 vs RB20, the only real advantage i would give the rb20 is sound... Inline sixes are sexy.
