So I bought my first 240 this past Saturday, a red 89 hatchback and it's amazing to drive. Got the car for 1900$ and everything is in immaculate condition, interior is perfect, ac works, power windows and locks work, drives great, and has not been in a wreck minus a dent in the front passenger fender from someone backing into it.
ANYWAYS, I expected to have some problems with it since it's such an old car so I'm not freaking' out about this too much. I've done quite a bit of research on the problem and I've only found mixed responses. When I bought the car the guy showed me that it had a very small oil leak due to a bad valve cover gasket, no big deal. So the other day I started preparing to do a bunch of preventative maintenance on it and I went to try and tighten down the bolts that hold the valve cover down and low and behold, the infamous stripped valve cover bolts. Almost half of them just kept spinning (I don't know how the hell someone stripped that many, but whatever). So I've done my research on helicoils and I'm fairly confident I can do it on my own but I can't seem to find a definitive answer on the correct size helicoil to use. In this thread(
zerothread?id=105906) I saw them recommend two separate sizes, 12 - 1.25 metric and 6 - 1 metric. Does anyone have a definitive answer on this or know any resources. I may have a shop do it for me next week if I can but I would like to do it myself if possible just incase it ever happens to something else.
Oh, I almot forgot, I did check to make sure the bolts are Ok and they are, if you look down the hole where the bolt goes it almost looks like someone yanked out the bolt with a pair of vice grips. I can barely see any threads in there, only remnants of them.
