Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Oct 10, 2009 3:13 pm
Over the years I've purchased 7 from ebay. 10" to measure before MAF, 20" to measure before TB plate. 1", 3", 10, 15" 20, 30, 100"
27.7" H2O = 1.00 psi
I have installed a measurement port in center top of air filter housing ~~ 7" at peak rpm, the MAF is 7" so 14" the hose to TB is 2" so 16" the TB is 2" so 19-20" to plenum with WOT.
Careful if you exceed the peak reading capacity of manometer [by much] it will suck out the diaphram and instantly destroy the unit.
You can rig a vacuumswitch/solenoid so that the vacuum path only works at WOT [use voltage from kichdown switch or just a manual if you remember to open when you let off throttle.
20" HG [cruise/idle vacuum ] is 9.8 x 27.7 = 272 " H2O .....14x greater
DON'T be confused by the numbers/test of the turbo which is 2-3x more sensitive to restriction on its inlet than a non turbo engine.
Reducing the Q45 losses from 7" to 2" [K&N cone] only seems to add 2-3 HP at best in cold weather.
