my fan makes me sound like a truck?
driven17
Car: 1989 240sx 5spd coupe
to sum up my problem, the clutch fan has began to sound like a huge MAC truck when it reaches about 2k rpms. And feels like its adding more strain but i cant tell.
Ive researched this problem, and it seems to be the belt driven fan. I want get it fixed as soon as possible in whatever way possible.
I was wondering if going to like autozone or napa and getting a new clutch assembly would work and i just replace them. or is this, i assume common, problem with the extremely loud fans more complicated.
Also by not fixing this am i running a greater risk of overheating? ill be doing a good amount of driving tomorrow
spooled240
Car: kouki s14
yeah your clutch might've just gotten siezed which is why it's not letting the fan slip a little. Can you spin the fan freely when the engine is off?
This shouldn't cause your engine to overheat as the fan is sucking in a ton of air through the radiator.
driven17
i just tried to spin it and that was a "no-go"
24j0hn
Car: 91' 240sx with some babying to be given
i had the same problem with mine and i went to pepboys and bought a hayden fan clutch and it works great... and it even has a lifetime warranty
