240z!!! »
https://forums.nicoclub.com/240z-u168778.html
Wed Dec 15, 2010 6:18 pm
as many i have been fighting with my rb25 for some time and i have lots of information that may be beneficial to others,
i use top hat mounts(never had a problem with them i would suggest getting the poly instead of rubber mount though).
i had issues when i first got my 25 with breaking the alternator/water pump belt(due to the fact that the previous owner lost the spacer for the bottom of the alternator) but it ended up overheating and warping the head slightly so i went with the full cometic street headgasket kit and never had a problem out of any of there gaskets daily driven and slightly got on for over a year(of coarse the head must be decked or a metal headgasket won't seal properly 9x out of 10.
rb coilpacks are perfect how they come and you should not need to upgrade them unless you have faulty coilpack, i upgraded mine by following myths and ended up wasting a good amount of money, i seen no gain
the usdm part number for the oem vtc sensor is 23796-97E08 and they come from the maxima with the ve30de(there are 2 vtc sensors on a maxima, one per head as i pulled muliple sets from the junkyard) i believe i paid a little over $100 for it brand new from nissan
usdm part number for oem injector seals to plenum are 16636-72POO( i believe i paid a little over $2 a piece for them (be careful as i checked with 4 nissans in my area and they all had different pricing)
for rb25 owners, im running a z32 ecu that is nistuned, contrary to popular believes im using the later 16bit ecu instead of the early 8bit and i have no problems what so ever and still retain the vtc, the wiring process is very easy which most of it is depinning wires and repinning them. and if you are deleting the vtc you can use the rb20 ecu nistuned and thats the only function you lose.
the hitachi and mitsubishi cas's found on rb20's and rb25's are interchangable, now the only difference between the rb's cas and j30's/300zx is that the position of the trigger wheel vs. the position of the keyway is slightly different(to be exactly it's 1.5 cylinders off in position, so if a j30's cas was bolted to an rb25 then it would fire whenever number 2 cylinder in the sequence is halfway down, i attempted to repin my firing order(so if my order is 123456 i repined it to 612345) and it ran the car but with the cas all the way advanced, so i then broke the keyway out of the j30 cas and positoned it so that number one cylinder fired exactly where it is suppost to(not easy but very doable) so there is a usdm replacement for cas's
what ive ben attempting to do lately is do a full rb26 valvetrain coversion on a rb25 head, this is doable with a good machinist, first the rb25 and rb26's intake/exhaust flanges are different, second they have the same cc chamber size so a rb26 head could be retro fitted to a rb25 if you delete the vtc, drill and tap the block to accept the 12mm headbolts (instead of the 10mm headbolts a rb25 uses) and get the itb setup and twin setup from a 26 ( or any manifolds that fit a rb26 because the 25 manifolds will not work)
so to make everything i have work i was just going to swap the valvetrain, you must have everything from the rb26 head including cams, the intake valves on a rb26 are slightly larger so cutting the new valves in is required, and the rb26 valves are slightly longer due to solid lifter setup, if you keep that in mind it can be swapped, i wish i could have finished mine but im just upgrading to a rb26 so im just gonna get rid of all my head parts
lastly my final adventure is im working on a r32 with the rb20 into it and were gonna swap a rb25 into it were gonna use the 20 trans due to cost for now, and were going to use the rb20 harness modified due to the rb25 previously being installed into a s13( it can be done, and its much easier than most think)
but for now this is a little of my story with rb's my fingers hurt and there are things im forgetting and will post them when i can remember and if you have any questions ill be happy to help if i can
