Straight imo. You'd look kinda ricer with that.bearsfan00 wrote:I custom did my exhaust from cat back 2.5 inches. But my question is what do u guys think about the position of the tip. Should I position it to another angle, maybe str8 back or should I just leave it as is??!![/IMG]
S14toRPS13 wrote:Keep it straight. That muffler doesn't match being at an angle.
im_looking_for_a_240sx wrote:go straight angled. or if you wanna be a bit different try a dolphin tip
whats with the big black areas on your car? what is that?zeedakay wrote:
the front is a 20mm+ wider fender and the rear is a 30mm+ over fender. the fronts are completely swapped out and the rears fenders are cut then attach that wider part hence "over fender" so i can fit wider wheels, widen the track, drop lower, and get sexier body lines. with the wheel widths i have (9 and 10'' wide) you can pull oem metal fenders out to fit but i didn't wanna do thatyoungmoney wrote:
Really? What the f***. Is this the body panel fitment thread? No.heartofaskyline wrote:wow those body lines dont line up at all. can you fix that or is that the best yall could do?
they can be better, but i also care lessheartofaskyline wrote:wow those body lines dont line up at all. can you fix that or is that the best yall could do?
