Loveless wrote:other than the noise, it just takes a little more gas to get the car going. It is nothing harsh like some claimed with lightened flywheel, or maybe toda is less harsh?
I reconnect the boost controller, it feels like I lost some torque in low/mid range but eh the car seem to scream at high rpm 5k+. I am not sure if it is the camshafts since it is only 256 but the idle is sometimes a bit lumpy
motor is checked out between 145 and 150 compression
it's not bad of a feeling, I have high anticipation for this car once it is tuned
i have a similar setup, except I have not lightened anything yet, and I went with the HKS 256in and 264out cams. I have an SSAC intercooler, greddy pipes, a Helix exhaust manifold, greddy o2 housing, 1.5mm head gasket, 60mm throttle body, freddy intake plenum, and a 4.36 VLSD.
Over stock, I def. didn't loose anything anywhere. I hit 17.5 psi a little before 4000RPM. My idle is a bit lumpy as well. Either turn up the Idle or deal with it is what I have heard. I would assume that it would stand true for your cams as well.
It does seem weird that your car doesn't scream until 5K. Mine really starts to pull a bit below 4000. you can really feel it when the gt2871r starts to get into its efficency range.
I am not taking the boost any higher until I install my greddy oil pan, RX7 oil cooler, and tune it a bit better. I have a lot planned for this engine when I swap it into my Kouki.
