apzak wrote: Even though this is 2.25inch, I miss the backpressure I had with the stock exhaust.
AHHHHHHHhhhhhhhhhhh...
Pet peeve of mine: "The Backpressure Myth"
Why does this set me off?
Because backpressure is an effect, not a cause. Backpressure is bad, no matter how you slice it. You want as little backpressure as possible, at all time, for any motor - N/A or turbo.
But what you want is velocity - High exhaust gas velocity adds to scavenging in high RPMs, creates power.
But to attain velocity, you need smaller piping...which creates some amount of backpressure.
So velocity is what you want, and backpressure comes along with velocity.
(Velocity is the cause, backpressure is the effect...)
The key is to find the ideal pipe size for the motor that lends to a high velocity, but can flow the needed amount of gas.
2.25" is OK for a KA24 with mild mods (say, up to 145rwhp). 2.5" or 60mm is OK until 155-160rwhp I'd say...and then at 160rwhp or more you need bigger...IMO.
So...sorry for the rant.
Later - Brian
