My engine sucks
CiPHeR_Tx
Ok...so the other day...I was driving home from work and i was sitting at a stop light. I glanced down at my gauges and my oil light flicked on and off...then the engine died. It started right back up again but had a rough idle at around 500 rpm. I get home with no more problems, besides the rough idle, and I check my oil...its full...I can't seem to figure out what the problem is...any info would be really helpful...in the meantime my car is sittin in the driveway...
skazzi
Car: Sports, Art, Music, Movies, Life!
Seeing as though these cars have a billion messed up sensors... Maybe a sensor is out?
gumby
Car: '89 240sx sohc
see if you can pull any diagnostic codes
CiPHeR_Tx
ran a diagnostic on the ecu...got a 55...no problems...wtf is goin on...
CiPHeR_Tx
also...it seems like it only does this when the engine is warmed up...rough idle...sometimes it'll drop below 500 rpm...when its cold and warming up it sits at around 700-750
ziggy682
Car: 1991 240SX Turbo
The reason your oil light came on is because your car idles too low. When it idles down, the oil pump isn't turning very fast, and oil pressure drops, turning on the oil light. Nearly any car will turn the oil light on if it idles low enough to die.
Idle problems, however, are not easy to fix. Noone ever seems to know the exact solution. Some things fix it on some cars, other cars have other problems.
CiPHeR_Tx
the oil light came on before the rpm dropped
CiPHeR_Tx
doesn't matter now...gonna be buyin a KA from some guy for 400 with transmission and new clutch...he just did an sr20 swap...thanks anyways for the help
180fan
Car: 89 fastback
check your oil pump? if you've a sohc, i should have a spare oil pump if you need it.
CiPHeR_Tx
would low oil pressure cause poor performance too? i have the timing set to factory specs
hondahunter180
Car: 2003 audi a4 - 1969 bmw 2002 - 1990 s13 (sold)
could be your MAF or your oxygen sensor.
hondahunter180
h
DoriftoMania
Car: car
its time to drop a sr20det foo!
evotech240sx
Car: 92 240sx fastback
sr20det???? just like that???? naw man.... stick with the ka
DoriftoMania
Car: car
you are welcome to ride in my s14 sr20det powered!
CiPHeR_Tx
heh....i'm gettin an sr20 as soon as i get the money...til then...i'm gonna have to rely on the KA...maybe even drop a turbo on that
xekushnr
Car: '90 Nissan 240SX Hatch
if you want to get a sr20, i wouldnt bother spending thousands of dollars turbo'ing a motor you're going to swap out. just save for the swap.
CiPHeR_Tx
no no...if i turbo the KA i'm not gonna swap
Bruno240
if you are thinking of turboing that motor, i would suggest getting it rebuilt bc somthing is wrong and you dont want to turbo a motor that isnt running right bc you will just **** the motor up even more wasting the money on turboing it
