andrews4356 »
https://forums.nicoclub.com/andrews4356-u139193.html
Sat Jul 25, 2009 8:56 pm
yea i drained it and replaced it, im thinkin its electrical, i had the car stripped down to just the shell and my dogs chewed up the wiring harness, so i ripped it all out, all i got is the ecu and engine harness, i got a fuse box from autozone and some relays, i wired the ignition switch to a relay that gives power to the fuse box, i got the black/red, blue/red, red, black/white, and red/black wires hooked to the fuse box, then i got another wire from the fuse box going to the fuel pump relay to power it and the black/yellow and the black pink and a wire running to the fuel pump, the light on the ecu turns on and the fuel pump pumps and i got spark, itll run when i pour fuel into the intake but im thinkin somethin with the air/fuel mixture its like its not gettin enough fuel
