The safcII adjusts A/f ratios only. What about the other features from a TS reflash, i.e. rev limiter mod, speed limiter removal, timing advance at WOT, etc.What is a wideband? Is it part of the safcII?kzoosho wrote:I got your run files. And i suggest getting a SafcII and a Wideband. NO need for a techno ecu. And if you get teh safcII you can adjust your tune anytime you want . SO there would be no need for a reflash if you upgrade again.
