12/25/11: Alright, I've got the head bolted on, the turbo manifold, wastegate, turbo, lower intake manifold, thermal gasket, and upper manifold all bolted on. I also got some new injectors to put in, and my brother in law gave me a bunch of Nissan oil filters he had laying around from when he had an S14.
Still have a bunch of little stuff to do, but it's almost there!
Pics of engine with head on from intake side, no intake manifold on yet;
Here is a pic showing the port and polish work I did to the sub-manifold. If I'm honest, this thing is kinda poorly cast. The opening to the upper manifold is considerably smaller than the gasket, and then it immediately chokes down even further once you get in a few mm. I had to remove A LOT of material from this to get it to gasket match. The 8 port manifold was WAY better than this.
Sub-manifold installed with pictures showing Gizzmo Phenolic Intake Gasket. I'm a big fan of this mod. They don't cost much, and it block so much heat from getting to the upper plenum it's amazing. Before installing this, I once burned my arm on the intake after running the engine hard on the highway, and then pulling off and I leaned on the intake to fix a hose that came loose. After installing this, it didn't matter how hard I ran the motor, the upper plenum NEVER got more than warm. Good stuff.
Here are some pics showing the HKS T04E turbo kit. I changed the turbine housing from the .48 A/R single scroll housing, 2.5" 4 bolt outlet that came with the kit, to a .58 A/R twin scroll housing, 3" v-band outlet. I'm expecting this to help it spool a little quicker, give a little better transient response, and help it keep breathing in the top end.
My new Deatsch Werks drop in 1200cc injectors;
And my new Nissan oil filters;
