deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sat Dec 10, 2005 7:17 pm
You dont need to get to extreme with your camshaft duration. You will have a large valve size and your piston acceleration will be slower (as it begins), which means more time for cylinder fill, less duration needed. Not an exact relation, but to get a good idea of the differences and to understand your duration needs, you can relate to average piston speed. This average speed doesnt take acceleration into account per say, but can be a good start to a comparison.
Find a piston speed calculator and enter the data for the Ka, and then for your new hybrid. You will see that for any given rpm, the piston speed of the ka is greater (obviously). You can generally assume that the camshaft will allow the engines to breathe in the same ranges of piston fps. So, with your destroked hybrid, you can obtain more rpms to equal this piston speed.
Now, some would argue that the average piston speed takes acceleration from tdc/bdc into account. It does somewhat, but does not take into account the length of the rod (rod to stroke ratio), which changes acceleration due to the difference in rod angle. Tayloring your cams to these piston movement characteristics is key.
What Im getting at is that you can use mild or oem ka 2.4l cams to produce different results with a hybrid rotating assembly. This is why the dual cam heads are more useful with a hybrid, less duration and lift is needed so the buckets/shims do not need to be enlarged, the main drawback to building high hp ka24de's.
The oem intake manifold for the 2.4l will be more than ample in runner diameter for the hybrid, this will also match the 2.4l valve sizes ports etc.. One (or more) of the multiple resonance characteristics of the runner length may fall into a range of use for your engine, you will need to do some calculating to get a general idea.
The ka24e ecu (240sx, stanza, truck) is very easy to chip and tune. You do not need any sort of daughterboard, you simply remove the stock chip and then install your tuned chip. It is a single basic 28 pin eprom. All that you need is a basic chip burner ($50) and a pc.
All emissions and vacuum that is not not necessary can be removed.
The stanza ecu is basically identical to the 240sx ka24e ecu, the only difference is that the stanza ecu can be connected to a pc or laptop for real time monitoring etc.. All tuning methods of the ecus are the same.
And yeah, the pacesetters do rust, they are like a year and half lifetime header, but overall not bad and a lot of high hp ka24e's are running them.
edit: btw, I will take some pictures of those rods tomorrow, they are at the shop.
