Sijonda »
https://forums.nicoclub.com/sijonda-u46716.html
Sat Dec 30, 2006 8:41 pm
well I'm having a similar problem. I have a 91 240sx. it's been overheating since i got it. I've replaced the thermostat and the radiator cap to see if this fixes the problem. One thing I'm wondering about is the fan shroud, since mine is missing.(cold start) The temp gage goes from cold to dead center and sits there, then after about a minute the gage tops out. I'm sure its correct since when I turn the engine off afterwards I can hear the coolant boil in the radiator and the reserve is full up to the overflow. I'm thinking the radiator isn't cooling the coolant fast enough "hence the missing shroud" I'm wondering if that shroud would make that difference.
