TonyMontana »
https://forums.nicoclub.com/tonymontana-u5531.html
Fri Mar 07, 2003 5:37 am
i email JUN the otherday to ask some question, and remakably they gave me my answers and prices within 24hours.
here ya go------------------------------------------------------------------
Thank you for your e-mail.
Regrettably we can not insert cylinder liners to SR20DET at this time.
Here is the reference for you.
We are currently trading directly from JUN head office in Japan to the customerin the USA and CANADA. Regrettably we do not have any work garage available inthe united states...so we can not do perfectly support for your tuning project.However we can provide our processing. If you are going to do our processing, itis needed you to send your engine to our company in Japan. We process and returnit to you.
We would like to know your car information.
What is your car name?What is year of manufacture?Is your car Japanese spec or USA spec?
Regarding Horsepower and Torque, it is changed by using turbine, boost, ECU, andetc...What we can recommend you is to find out the person(tuning shop) who can set upyour ECU with your car locally. I think this is best for your car.
Here is the reference for you.This menu is FULL tuning spec.
Parts*JUN solid type camshaft(you can choose the cam profile.)*JUN racing valve spring*JUN titanium valve retainer*JUN racing valve guide*JUN lash killer kit*JUN Stroker kit 2.2L
ProcessingValve guide change & ReamingRemoving squish areaSeat cut with stem height measurementLash killer processingValve tapping & CleaningHead surface cuttingValve polish processingPort polish processing Tappet shim clearance adjusting
Block upper surface polish processingBoring & Horning with dummy headPiston ring clearance adjustingMetal measurement adjusting
Packing chargeHead parts set upBlock parts set up
TOTAL COST is JPY1,435,220yen.The exchange rate for today is USD1.00/JPY117.33 You can get USD amount bydividing the total Yen price with JPY117.33
*It is needed NISSAN stock parts(valve, rocker pivot, rocker spring, rockershaft retainer, tappet shim, and etc.) for RNN14 because the head is changedinto solid system from lash system.We can prepare the NISSAN RNN14 stock parts.
NISSAN RNN14 stock parts cost is JPY63,440yen.
Time takes about 2 month.
Kind regards,
Yutaka Chiba JUN Machine Shop (Japan)-------------------------------------------------------------------
wow, thats an expensive price $18,000 canadian dollarsi didnt know it would cost that much
