My driverside window won't go up!
infinitik
Car: infiniti j30
Hey nicoclub, I'm new to this here. I've checked out posts in the past and they have been informative. I have a 93 J30 that has been a challenge to me over the past year. The most resent ordeal has been my window. It won't go back up. I hear the motor running when I hit the switch up, and when I click down it runs and runs until I click it up again. I'm stuck now at trying to remove the door panel but I can't figure out how to remove it. There seems to be something holding it on the other side of the arm rest. I'd appreciated any help I can get to get this fixed. Thanks
puck
Car: 1997 Infinity J30
Check out this website, it'll tell you how to do it.
http://fuzzycats.com/j30.htm
infinitik
Car: infiniti j30
Thanks I'm a give it a shot!
[email protected]
Car: 1997 Infiniti j30t
Just finished replacing the window regulator in my grandson's j30t while he's in the army learning to be a medic. Anyway, it is very likely that since the motor runs, this piece is reparable. Basically two procedures: 1)Getting the door skin off and 2) Removing the Regulator1)The skin has 3 exposed screws at the bottom, the usual plethora of plastic body clips and 2 hidden screws in the central to upper middle portion of the door both of which can be accessed by carefully lifting and removing the window/mirror control panels with a wide blade screwdriver. Careful: these plastic/bakelite parts are old and can be brittle. (Generally, these panels are held in by a built in plastic hook on one end and a metallic friction clip on the other. The escutcheon around the door handle is simply friction clipped in: Hold the handle open and slip the escutheon out. Now you can lifte the panel, snake the controls through the openings (Don't disconnect the window control panel. You'll want it connected to lower/raise the window glass and check the new reinstallation), disconnect the gas tank and trunk switches and lay the skin in the back seat.2)Disconnect electrical and Remove the Regulator with the motor. a)Position the window so you can remove the 2 screws holding the glass to the cable/motor/regulator mechanism b)Then remove 4 screws (2top/2bottom) from mechanism, turn and remove it from door.
(At this point I found a used working regulator, but if the motor runs, you very likely can remove the circular cover, observe that the hard plastic/rubber clutch has deteriorated, clean and pour in a setting plastic resin and after it hardens reinstall the whole mess after you clean the track and lubricate generously with lithium grease. Note: This fix will work because, in all likelihood, it is the track and/or the window friction which will have caused this rubber clutch to fail (it having been engineered to preserve the motor, but you likely couldn't buy just the motor anyway. In any case the odds of breaking the window are remote if you lube the edges and you have fixed your window for pennies!
driverdriver
Car: NICO's longtime resident Canuck!!!
[email protected]
Thank you for your informative post.
