Any idea what might be causing this?
Regulator or something with the track I'd guess.08.black.G37 wrote:Okee doke...thx. What makes that clicking noise? It is actually more of a popping noise.
Your thinking of the V35 those had the window timing reset buttons. The new ones use the switch to set the limit time. The motor still has the anti pinch feature which if it were to fail can cause problems like this. It is not common but not un heard of.audtatious wrote:Just take it in and let Infiniti fix it. If the window goes up then drops 4" you usually have to go through the door panel and hold the reset switch. You should not have noises so again I suggest you drop it off at Infiniti.
