tyrannix »
https://forums.nicoclub.com/tyrannix-u27595.html
Tue Nov 08, 2005 9:58 am
take off your inner door panel (theres a few screws, then just start at the bottom and just pull, they snap on/off)
look for holes about an inch or so from te top, one towards the front, one towards the rear of the door, they should have a screw, and a black plastic "L" shape, these are the upper limits of the windows, adjust them up/down to change where the window stops at the top
edit>if this *just* started happening, then one/both of the limiters may have loosened/fallen off, if you cant see them where tehy should be, roll teh window all teh way up, and shine a flashlight/feel aroundthe bottom of the inside of the door
-CJ
