MY DOOR IS LEAKING
thedon'sG35
Car: 2004 G35 sedan
Hey guys,I was wondering if anyone else has/had a problem with water leaking in from right above the window. There is wether stripping and it does not look damaged at all, but there is still water coming in. In tern, my G35 is light beige so where the water is coming in the interior is becoming discolored. Any thoughts ??? Thanks.
G_whizz
Car: 2010 G37 Coupe Sport
Just to be 100% clear...are you talking about the weather stripping along the roof line or the window?
Does this happen when it rains or when you spray it with a hose/carwash/powerwasher?
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
+1 for a better description. Water leaks can be illusive either you or whomever you take it to will need to trace down the point of entry and seal it, either by adjusting the window regulator or replacing the weatherstrip.
thedon'sG35
Car: 2004 G35 sedan
weatherstrip is inside the car, and only when it rains.
telcoman
thedon’sG35 wrote:Hey guys,I was wondering if anyone else has/had a problem with water leaking in from right above the window. There is wether stripping and it does not look damaged at all, but there is still water coming in. In tern, my G35 is light beige so where the water is coming in the interior is becoming discolored. Any thoughts ??? Thanks.
Well you could just not use your G in the rain.
Try calling Circle Infiniti on Rt 36 in West Long Branch. Ask for Todd in Service. 732-389-1200 Tell him Howard recomended you.
Telcoman
