Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Oct 03, 2007 5:02 pm
By diagnostic screen - you mean the one on the dash? The dual trip meter that also says thinks like "OK" or "Tail Light Out"?
To my knowledge, the only codes you'll pull with that screen are transmission codes - and it's not done with a code reader.
The info screen on the dash is backlit by two bulbs, so if they're out - you won't see much. You might be able to shine a flashlight at them to see if the numbers are there - even though there's no light behind them to illuminate them.
Good luck!
Heath
