Small world indeed!
The Edda Fauna is ours as well, just under a different contract. You're running ok, you were running very smooth until about 30 minutes ago, then your RX snr's started fluctuating about 3dB. Could be caused from some sort of blockage or bad weather. It could be a tracking issue but it was tracking very very smooth until then.
Your BUC is a 16W and we normally don't see them running at max power, however yours is. Next time in port I would have the ET/ITO call and perform a 1dB and cross pol test to make sure your power limits and polarity are set properly. If it's not adjusted 100% it will affect your BW speeds, although you've been peaking over 1M down and 100k up.
I can see your location, looks like you're heading north at 1 MPH. (scary huh? )The farther north you go, the lower your elevation and the more atmosphere you have to "look" through, so the RX signal will only deteriorate the father you get from the equator, conversely the TX will require more power, which you don't have any more left to give.
You can view the footprint of 10E or W2A on
http://www.lyngsat.com, if you get bored. Although I don't see that happening any time soon though with all those pretty machines onboard!!!
