DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Feb 23, 2003 1:44 pm
I won't disagree that certain applications use torque-to-yield bolts, but I've never heard of having to replace rocker cover bolts. In general bolts all rely on pre-load (tension) to 1) keep parts together, and 2) develop enough friction to keep the bolt from rattling loose over time. Once a fastener yields, its strength and integrity have been compromised. Except for a short period of strain hardening, a yielded fastener will never be as strong. Every single 4mm bolt, torqued to 5 foot-lbs, can create as much as 1900 pounds of compression between the head and the rocker cover! Given the area of a 4mm bolt, this puts a stress of roughly 103,000 psi on the bolt. Luckily steel has a yield strength somewhere around 150,000 psi, meaning that it will NOT yield. Hence, no need to replace them if you torque them to spec.
