I can see exactly what you're saying, but IDK if thats a good idea altogether. It would be more compact than running 4-1bbl downdrafts, but the double pumper is made to work as a unit, not as individual runners. LIke I said IDK how 4bbl carbs work, so...Drift21_Hardslider wrote:A crazy idea I had using a double pumper carb. to make a type of individual fuel intake. The runners would be a pain, though.
If what I've been told is correct, a double pumpers' secondaries can be opened with the primaries. IDK, I don't work with carb.s.seang wrote:I can see exactly what you're saying, but IDK if thats a good idea altogether. It would be more compact than running 4-1bbl downdrafts, but the double pumper is made to work as a unit, not as individual runners. LIke I said IDK how 4bbl carbs work, so...
Where the heck can I get this?? That would be easier for me, too!PEZi720 wrote:
The manifold I drew up has tuned runners that can be made for any given torque curve. I think the line between a DCOE setup, and my little design could be a thin one.PEZi720 wrote:i'd like mikunis with a custom intake... its a little easier intake to make than yours because the ports don't all have to come into one.... and you get much better performance!
well... you can get them by searching 'mikuni side draft carbs' in classifieds... ebay etc.Drift21_Hardslider wrote:
i'm interested for sure man... just let me know how it works out because this plus a weber is bound to be cheaper than running mikunisseang wrote:
basically yes... but people have less issues with mikunisseang wrote:
Oh, the reason for this post. Aren't Mikuni sidedrafts exactly like a Weber DCOE? I thought they were shared designs.
nice... for some reason i didn't even thing of thatDrift21_Hardslider wrote:I wasn't talking about the carb.s, but the manifold itself. I can adapt it to use my throttle bodies.
Actually, I'm using Baja: Edge of Control.seang wrote:I hope you do well, drift21hardslider, and achieve the goals you have set forth in your racing agenda.
P.S. Gran Turismo can be excellent practice.
I say if you're going to do that, just use a 240SX intake. I've got a spare one lying in my truck.seang wrote:OK, I have been thinking about BS carbs, now I have another idea. Take the stock components off my truck style ka24e manifold (downdraft throttle body w/integrated MAF, all 4 injectors, vacuum accessories, and fit them onto the new manifold. It seems practical because the stock throttle body mounts just like a carb or TBI would. I would have to add the injector bosses on the runners. This would utilize all the stock parts. What do you think?
That would work, but I want something more eccentric than that.Drift21_Hardslider wrote:I say if you're going to do that, just use a 240SX intake. I've got a spare one lying in my truck.
I was digging around in the engine compartment the other day, and I realized I could utilize the full 19.09 inches of the runners which would ram air into the cylinders. The stock manifold already does this kind of well, but I think I could still optimize it more. I have found a company that does custom size aluminium tubing, so that part is taken care of as long as its not too pricey, by which I mean anything more than cheap. I would mock the runners up using PVC U-bends and pieces of pipe before finishing in alminium. It would take some time to get them exactly the same length. 19.09 inches isn't really that long, and it would fit under the bonnet for sure. Mind with runners that long, I would be sticking with the stock fuel injection instead of a carburetor. I say stock FI components because I already have every piece, and it would keep the costs down.
PS, the more I think about this project, the more impractical it becomes. The only reason I continue to talk about it at this time is that it gives me something to think about.
