240z4u »
https://forums.nicoclub.com/240z4u-u26156.html
Sun Jul 02, 2006 9:42 am
As long as you did not cut any of the cruise wiring out of your harness or remove any of it this is pretty easy stuff.
Your speedometer works, right? Hopefully you used your KA lower harness to get everything working. This is very important.
Let me start this by saying, I do NOT have the small bugs worked out yet but am going to get them ironed out. The speed control is not the greatest, it does surge alot. This may be specific to my car because of a few reasons.
I used a cruise pulley from a pathfinder, its outer dia. is signifigantly larger than the one for the throttle. because of increased required pull distance of the cable to change speed.
The cruise cable is definitely bent, could be causing friction.
My speed sensor is not the correct unit, so I recalibrated my speedometer. This speedo sensor I used tricked the KA speedo into reading super high (like almost double). This makes cruise think I am really hauling butt, but I am not. The other problem that has left me with is the cruise will not engage over 50mph because the speed sensor thinks I am going very fast. I am going to swap in the right sensor, recalibrate the speedo, and see if that does the trick there.
Anyway, when I did my wiring harness I left every cruise wire intact. If you did not, get out your manual!
I used a pulley off of a pathfinder, with a little modifying it fit right onto the RB throttle body. This DID involve a couple tack welds and a dremel.
Thats it though, I just hooked up the cable and it worked. Wierd. I figured something much more sinister was going to be required.
I am at my parents house, but will post pictures of what I did when I get back home!
Evan
