my crancky ka. Grr.
thekage
Car: 98 Dodge Caravan
98 Dodge Intrepid
Ok so my engine in my new 240 is running like trash. Really crappy idle, shaky, and has no low end power what so ever. I mean whatever. When the engine is cold the low end power is better, but after it gets warmed up.. forget it. So I changed plugs, wires, cleaned the rotor, and set my timing. The idle was a litttle better but not much. So I started pulling wires while the engine was running. When I pulled the wires they all started to kill the engine but the 3rd cylinder. So I have issues there apperantly. No smoke comming out of the engine.. So Im not burning oil or fuel.. I want to get a compression test tonight to help me further diagnose..I am really hoping it is something as simple as a valve sticking so I have no compression whatso ever in that cylinder. Any other thoughts?? I think that if the piston ring was toast it would have some compression and I would burn oil right?The engine is a 91 with only 120k.Any thoughts would be appreciated!
tiger
well, you covered everything that I would suggest, so there's definately something going on with the #3 cylinder. I don't think you would burn any oil unless your head gasket was leaking or you had some bad valve seals. Yeah, test your compression. Is your computer throwing any codes besides 55? I know how it feels to have your motor not running correctly, mine just recently bit the dust and i'm working on that still. (spun bearing and blown head gasket). post up your compression results when you get them.
InsanityInc
Just pull the plug on cylinder 3 and look at it. Covered in gas means the injector is screwy, or the plug itself might just be destroyed which means no spark.
thekage
98 Dodge Intrepid
Plugs are fine. They are brand new and gapped correctly. And no gas on it.
thekage
98 Dodge Intrepid
any other thoughts insanity?
tiger
kage, that van on your sig is hillarious... you should see the clans of those things driving around, they look like batmobiles... they even do it to the vans ... all purple with airbrush paintings. HUUUGE wings on the top of the van like REAL wings, bat wing looking wings.. hahah
zero_gripS13
Car: soon to be 95 s14 hopefully
ur in
thekage wrote:Plugs are fine. They are brand new and gapped correctly. And no gas on it.
jector is bad.. i just replace my 3rd injector yesterday...
symptons.. shaky engine.. no power.. bad miss....plus ok.. spark ok..fuel injector is the problem.. :P ..
get a volt tester and test the volts on a good cylinder (test in voltage and out voltage..) then do the same for bad.l. i bet u dont get good resding.. its bad replace
