my compression test results...
whoareu
Car: 1993 rb25det s2 240sx vert
i basically got 130 across all cylinders. this was performed on a warm engine. all were with 5psi of each other.
im pretty much screwed right... i searched and im seeing most healhty engines are seeing between 140 to 160s across all cylinders. being that they are all the same im curious the engine is shot or if its good... perhaps the compression tester just reads low maybe.
what are you gents thoughts???
Carl H
it sounds low for sure but it may be the tester.
did you hold the motor at WOT while cranking?
what does your idle vac look like?
RRRRB
Car: 98 RB powered S14
Do you have stock cams? or adjustable cam gears?
whoareu
i did another run on all cylinders with all plugs removed and at WOT and got 150 across all cylinders. which im fairly certian is good. thats a relief.
RRRRB
even 135 is acceptable, the main thing is that there all consistent with one another
