My clutch won't engage. help?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
FiveSeventyZee
Car: '72 570z & '80 720
zer...ngage
sorry, didn't realize this existed, I guess thats why I should have read the whole "datsun truck owners read here" lol. oh well, now its in both places. Any ideas?
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
YO. Check the whole clutch hydraulic system. Start at the pedal and push and see that it feels like the plunger of the master cylinder is still good, then go in the engine bay and begin at Clutch master follow it around to the slave looking for leaks or anything. Look at the slave and push the rod in and if it is working. Move the throwout fork and see that it doesn't get hung up pivoting on the trans.
Then fill the res with fluid and do it again looking for leaks. If no leaks then get a friend and bleed the clutch and if you are worried drive around with clutch fluid like some of my friends do.
Anything else will probably require removing the trans. 2wd or 4wd?
FiveSeventyZee
It's 4wd
2kredz3
Car: 1984 Nissan 720
I will be replacing the slave cyl on my 4x4 in the next week, i will post pics on how to do it at that time. mine has just started to do this and for 20$ its the cheapest place to start replaceing stuff.
FiveSeventyZee
I'm going to pick the truck up Friday. I'm gonna check out the hydraulic system and see if I can fix the porblem. If I can't do anything about it or make it roadworthy I'll just start it in 2nd and drive it to a transmission shop nearby. The good thing is it's surrounded by transmission shops so it won't be hard to get to.
2kredz3
let us know what happens.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Had thensame problem when I installed the 5fwd. Used the wrong release fork, made a new rod from the slave to the fork got it to work then realised the fork was from a L18 box. will change the fork when installing the Z20 engine.
FiveSeventyZee
Mkay. I'm goin early tomorrow morning. I'll be bringing some box wrenches, some adjustable wrenches, some brake fluid and the most important tools ever...duct tape and WD40. I'll be sure to post about how it goes.
If I can't fix it I found a clutch shop that'll do a clutch replacement for $550 and a hydraulics replacement for $150. It's like 2.7 miles away so I'll be able to get there okay.
2kredz3
sigh, epic failure on my slave cyl replacement. . .seems that i was shipped a slave cyl that has a different sized bleeder valve then what came on my truck so i had to install the old one back on.
FiveSeventyZee
Well we couldn't fix it ourselves. The hydraulics worked fine so it needs an entries clutch replacement. We took it to a shop up there. That was a fun little adventure haha. My dad was driving it and he had to turn off the engine every time he stopped.
Well it'll be done by Tuesday so atleast I'll be done with this and Ill have a car to drive.
2kredz3
kwel, doesnt sound like a bad price to pay for it either. . .i mean the clutch is like 100ish just for parts.
FiveSeventyZee
Yeah. I just wish labor wasn't so expensive
2kredz3
FiveSeventyZee wrote:Yeah. I just wish labor wasn't so expensive
yep, but a lot of that labor cost you can thank snap on tools for. . .since they charge so much for the tools the mechanics get a primium for their use. lol
Return to “Datsun 720”
