my clutch squeeks
W240sxLE
Car: white 240sx le
when i push my clutch pedel in it makes a squeeking sound dont know what it is
DarkStar
Car: '93 Sil80
Is it coming from the pedal or the transmission? If its from the pedal, I would say just spray some wd40 or other lube where the squeek is coming from.
TheOne
Car: 93 240sx FB
if its from the transmission, sounds like your throw-out bearing is goin out.....
sanioll
Car: Nissan 240SX SE
Toyota Camry
its the spring from the clutch pedal. not matter how much grease you put on it, it still does it. its gone for a day or two, but next day its back.
this occurs especially when its cold, during the winter.
Dattebayo
Check under the dash and around the pedal.Look for a little mouse and make him find a new home. Problem solved.
