cleopp3 »
https://forums.nicoclub.com/cleopp3-u92460.html
Sat Nov 01, 2008 4:56 am
probally blew your slave cylinder, sits on right hand side where fork sticks out of transmission. other possibilty is the master cylinder which sits directly in front of the driver under the hood. check fluid in master, the brake master is on the oposite side to the left. any fluid signs are symptoms of a leak. if any need to replace make sure u look up the "dampener delete" while your at it. order from pedal(master to the dampener loop to the slave)
